My Canon IXUS 220HS records HD video to .MOV files (MediaInfo dump below).
I have two questions:
1. What software will allow me to do basic edits such as splitting and combining these files?
2. Is there a format I can convert them to that will be smaller in size but still HD quality?
General
Complete name : G:\Temp\MVI_0011.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 140 MiB
Duration : 33s 492ms
Overall bit rate : 35.2 Mbps
Encoded date : UTC 2011-07-23 04:12:49
Tagged date : UTC 2011-07-23 04:12:49
Video
Format : AVC
Format profile : Baseline@L5.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Bit rate : 33.6 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.676
Stream size : 134 MiB (96%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 6.13 MiB (4%)
Language : English
1. avidemux or mpeg streamclip.
2. You can also shrink with those tools. Convert to h264 and lower the video bitrate. Or use a simplier software like freemake video converter.
Testing H264/AVC frame accurate editing (AVCHD/MOV/MP4/MKV)) of SolveigMM
By DmitryV in forum EditingReplies: 17Last Post: 20th Oct 2023, 06:47 -
Why should get a delay when converting H.264/MPEG-4 AVC?
By Leo99 in forum Video ConversionReplies: 31Last Post: 16th Apr 2012, 14:40 -
Editing H264 MPEG 4 AVC .ts files?
By grave101 in forum MacReplies: 14Last Post: 24th Nov 2010, 05:12 -
Converting/editing MPEG-TS container with AVC/AACvideo
By Omega81 in forum Video ConversionReplies: 10Last Post: 28th May 2010, 18:03 -
Converting H.264/MPEG-4 AVC to DVD
By KiteFlyer in forum Video ConversionReplies: 1Last Post: 23rd Jan 2009, 14:36
