i wanted to know whether i could convert a (VCD) .mpg file to an svcd file. which program would i need?
Thanks to all that have replied!!
Load the mpg in TMPGenc (in tools section) and load the svcd template and hit encode.
This process would be pretty pointless however. If anything the quality will be worse and it will only make the disk less compatible on dvd players. The only reason to do this would be if you needed to add a 2nd audio track or have selectable subtitles. If this isnt the case then just leave it as a vcd.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Encoding VIDEO_TS to mpeg-2 SVCD
By phamtom in forum ffmpegX general discussionReplies: 6Last Post: 27th Apr 2008, 15:05 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
