    Sep 2007
    somewhere in videohelp
    hi, usually TmpgEnc can open all avi
    but there's were some avi can't open, when i open it show this
    this in info that TmpgEnc can't open
    i have FFdshow, do i need another codec ?
    Sep 2007
    sorry, have reedit the pic
  3. Make sure ffdshow's VFW AVC decoder is enabled:
    Start -> All Programs -> ffdshow -> VFW Configuration -> Decoder (tab) -> Codecs (left pane) -> H.264/AVC (right pane)
    Sep 2007
    setting have change to libavcodec, but still can't open these avi
  5. Try enabling the DirectShow h.264 decoder too:
    Start -> All Programs -> ffdshow -> Video Decoder Configuration -> Decoder (tab) -> Codecs (left pane) -> H.264/AVC (right pane)
    Sep 2007
    it only have this option : disable & libavcodec
  7. Are both set to libavcodec? There are two places you need to enable h.264 in ffdshow because there are two video systems in Windows.
    Start -> All Programs -> ffdshow -> VFW Configuration...
    Start -> All Programs -> ffdshow -> Video Decoder Configuration...
    Sep 2007
    both already set to libavcodec.
    when i open in virtualsub , it show this
