Hello friends,
Quite challenged when it comes to technology. Languages, yes. Electronics, NO.
We use ATT U-verse as our TV provider. I copy a lot of educational programs from TV Japan and have been transfering them from the DVR to DVDs; however, the Panasonic DVD Player/Recorder is horrible and has given more problems than I care to have.
OK, the main problem is this: I want to use my DVD machine as an external unit, i.e. NOT programmed to my DVR remote because then it does not permit such program copying.
The setup I use (AND WANT TO USE ON ANY NEW MACHINE) is simple: Connect the DVR output to the DVD input with an RCA cable.
I want to beable to SEE the few commands I need to use either on the DVD remote OR a screen on the front of the machine without having to see any TV on-screen menus. THE only commandes I need to use are the recording mode and insuring that I have the correct input. I also want Auto Finalize.
I am intrigued by the Toshiba D-RW2 because it has exactly all of that, BUT although I can buy in on Amazon it is a discontinued model, meaning no tech support.
I have checked on the DR-430 but it does not seem to have any screen on the front.
Any and all advice will be welcome.
Gene
Pelham, AL
If you need something that does not require a TV for set up to re-record programming to DVD, the only thing I remember seeing that could work is this: http://www.amazon.com/Sony-VRDMC6-DVDirect-Compact-Recording/dp/B002EVP85K
Thank you. It certainly has given me something to think about other than the Toshiba D-RW2. According to a Toshiba rep I spoke with, it does have the few controls I need on the front of the machine or on the remote without having to see any controls on the TV screen.
Gene -
Tiger Direct has refurb VRDMC6 for $99.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6713376&Sku...424&TId=2&SF=1Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
getting recordings off comcast dvr
By Knightmessenger in forum Capturing and VCRReplies: 1Last Post: 15th Aug 2011, 19:34 -
Moto DVR DCT3416 from Comcast - can I get the recordings off the DVR?
By jmkeuning in forum Capturing and VCRReplies: 42Last Post: 7th Jul 2010, 18:44 -
Transfer my first recordings from my Canon HV20 to my Mac G5?
By Anne-Marie in forum MacReplies: 5Last Post: 5th May 2009, 21:43 -
How can I transfer DVR recordings to MacBook Pro?
By Doomferret in forum MacReplies: 3Last Post: 28th Mar 2008, 09:56 -
Help getting recordings off HD DVR onto DVD in 16:9 – not 4:3 - Please!
By ChrisU2Edge in forum DVB / IPTVReplies: 3Last Post: 12th Jul 2007, 21:43
