    Jul 2011
    romania
    I have a problem with PopCorn MKV Audio Converter 1.84.
    When i try to converse MKV DTS in AC3 i get the message:
    "Your Windows Explorer is set up to hide
    extension for known file types,
    which may confuse AudioConverter.
    May I disable this option ?" Yes / No ?"
    Can I set to "No" ?
    I use Popcorn since december 2010 but the old version did not have this problem.
    Sorry for my bad english.
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Choose "yes". It's a stupid default Windows has to hide extensions, causes any amount of confusion and allows deception.
    I didn't look at your 4 MB bitmap. Convert screencaps to jpeg, and they are much, much smaller and will display inline.
    Nov 2010
    belgium
    Hello,
    When I run the tool v 1.87.6, I get the error the file 'besweet.exe' is missing (appearing on a line with red background).
    then I click on the internet icon to download it; but the download does not start...
    So my question is : where can I download the besweet.exe file from ?
    Thank you !
    Click on besweet. Put the exe in same folder as popcorn.
    Nov 2010
    belgium
    Hey thanks for your fast reply, and it works !
    Do you know why all the related exe are not packaged with the tool itself ? Why do we need to grab all the separate files and dlls one by one ?
    Oct 2005
    Here recently I've been having trouble with Popcorn mkv audioconverter. The past few videos I tried to encode my computer will shutdown right in the middle of the encoding process I attached a screen shot of the setting I have for Popcorn. Like I said this problem has been recent so I don't know what the problem could be any help would be appreciated. Click image for larger version
    I Love This Game
