I recently purchased a region 4 dvd. I`ve tried a few different methods of ripping. RipIt4Me, DVD Decrypter, and DVD Shrink.
When the iso is finally finished, i try playing it in VLC and i notice "Lines running through it". Now, i could easily just use the VLC option of removing the interlace but that won't help if i burn the dvd. So, i was just wondering, will the interlace still be there if i burn the dvd and try to watch it on my tv?
If it remains the same, is there a way to remove the interlace in the process of ripping the dvd?
Anyway, thanks in advance for the help![]()
Results 1 to 9 of 9
No, you wont see any interlace lines on your TV if you are using a standalone dvd player. It should look exact the same as the original dvds.
I'm still a little confused. So since Dvd Decrypter makes the iso region free, there won't be lines on the tv? But why does VLC show the interlace then?
Because you are watching on a progressive computer monitor. Select one of the deinterlace modes in VLC player under "Video" tab. "Blend" uses least CPU, "Yadif" gets best deinterlace result.
You can also select "auto" deinterlace under preferences.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
No. It will still be interlaced because it is supposed to be interlaced if you are watching it on a TV. Also removing the region code does NOT mean the DVD will be playable on your TV. A disc with the region code removed will still be either PAL video format or NTSC video format.
DVD players and TVs are designed to handle interlaced video. Removing the region code is the same thing as making the disc region free. Both refer to setting the region code (just a number on the DVD) to "all regions". You still have the issue of whether your NTSC DVD (720x480, 29.97 fps) player and TV will display PAL (720x576, 25 fps) video correctly.
Region 1 Samsung dvd-vr375 to switch to region free
By catleo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2011, 11:25 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
Total Newbie -- Best/cheap way to rewrite a Region 2 DVD to Region 1
By jteselle in forum Newbie / General discussionsReplies: 6Last Post: 3rd Nov 2009, 12:49 -
hdv/dv to dvd: to deinterlace or not?
By arod0405 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2009, 10:07 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 13:58
