Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    Aug 2002
    Florida
    I have a Blackmagic Intensity Pro card. I am using a HDMI to HDMI with a set-top box. I am looking for an option to be able to watch TV on my PC with this card as well as able to record TV on my PC. Anyone have any ideas? Thanks in advance.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    The BM Intensity will not sync HDCP sources.
    http://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection
    http://www.kiva.org/about
    Aug 2002
    Florida
    My box does not use HDCP
    Aug 2006
    I think I remember reading that AmaRecTV can work with the Blackmagic Intensity Pro. http://amamaman.web.infoseek.co.jp/english/amarectv_e.htm
    If not, it should still be possible to build a filter graph in Graph Studio for watching TV. Recording TV using a program guide is a different story. I haven't heard that any of the standard guide-based PVR software supports the Blackmagic Intensity Pro as some can support the Hauppauge HD-PVR or Hauppauge Colossus.
    Aug 2002
    Florida
    Thank you that worked perfect
  6. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    A bit OT but really useful
    Thanks for the link usually_quiet I used it to get something else.
    There's a pretty robust screen and audio
    capture app on that site. It lets you capture by sizing a target frame over an area or by selecting a specific target window using the api. The required default codec which must be downloaded separately is really fast but it's watermarked. However there is a setting that allows using another compression codec.
    There's not much to do but then I can't do much anyway.
