I have a Blackmagic Intensity Pro card. I am using a HDMI to HDMI with a set-top box. I am looking for an option to be able to watch TV on my PC with this card as well as able to record TV on my PC. Anyone have any ideas? Thanks in advance.
The output of the set top box is almost certainly HDCP encrypted. You won't be able to record anything via HDMI. I don't think the BMIP will even let you see HDCP encrypted video on your computer. Try capturing from PBS -- that's the least likely to be HDCP protected.
Search for HD Fury III on web, You will have to use the component input/output. Use the capture software from Intensity to watch on computer. For audio monitoring you need to feed the audio out from Intensity to audio input on computer or audio card (use high level input 1v not microphone.)
rcubed
Blackmagic Intensity Pro Help.
By MoonVid in forum Capturing and VCRReplies: 1Last Post: 4th Nov 2011, 16:10 -
Blackmagic Intensity Pro 3.5.1
By Lynas in forum Capturing and VCRReplies: 24Last Post: 10th May 2010, 13:28 -
Blackmagic intensity pro help
By Smify123 in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2010, 11:19 -
BlackMagic Intensity Pro
By Richintx in forum Capturing and VCRReplies: 0Last Post: 23rd Jan 2010, 09:43 -
Blackmagic Intensity Pro + Xbox 360 Hookup Question
By xmadmardiganx in forum Capturing and VCRReplies: 6Last Post: 15th May 2009, 16:52
