  1. Hi,
    What's the best cdr or cdrw to go on (which type, brand, etc) if you like to burn them for vcd and svcd?
    I use "Samsung CDR-W SW216-B" driver.
    Thanks in advanced...
  2. What's best is what works in your player.
  3. condone,
    THank you for ur kind replay...
    kinneera,
    nooooo......REALLY??!
  4. Quite frankly, ask a stupid question, get a stupid answer. The type of disc makes no difference, whether you're writing VCD/SVCD or regular data to it. Just get the cheapest brand that works in your damn player.
    Mar 2002
    USA
    yeah, I would have to agree with most the other replys...
    I've used many brands, mostly whatever is the cheapest when I need to buy more CDRs... all that I have used have always worked fine.
    I find most problems in burning are due to the software or the burner itself not the media brand.
    P
