Hey guys, I'm new here and don't know too much about Blu-ray ripping. I was wondering how can I take an MKV video file that is 7.92gb and convert it to a DVD9 disc without losing video/audio quality and play and watch it on my Blu ray player? thanks
AnonymousGuest
Try MultiAVCHD. I believe you can use that to create a VideoDVD structure, and/or also use it to create an AVCHD structure from the MKV, if your BD player supports it. Note that converting to DVD will probably still be a bit of a drop in quality (HD to SD).
Witch the best way to convert a BluRay Movie to MKV ( size DVD9 or else)
By siopilos in forum Blu-ray RippingReplies: 9Last Post: 12th Feb 2012, 20:59 -
Convert MKV DVD9 to MKV DVD5
By CR88 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2011, 07:55 -
Easy MKV -> DVD application? Want 5.1 and max quality (4,4 GB or DVD9)
By bjorsa in forum Newbie / General discussionsReplies: 19Last Post: 3rd May 2010, 12:08 -
Quick and easy DVD9 to DVD5 video backup under Linux
By danboid in forum LinuxReplies: 7Last Post: 30th Sep 2007, 11:05 -
Convert MKV to AVI?? Is there an Easy Way like with VirtualDUB
By sandman423 in forum Video ConversionReplies: 4Last Post: 30th Jun 2007, 13:41
