I need some help, I am transcoding (to mpeg2) some miniDV footage originally shot with the DVX-100, exported from Avid using the DV Codec at DV25.
Procoder is the only encoder that causes the chroma sampling error, meaning the reds have visible vertical lines (the bright oranges too). Is there a way to fix this?
Are there any filters or settings I can tweak?
Procoder 3 gives by far the best results overall (compared to CCE, Digital Rapids, Sorenson and others I have tested) so I do not want to abandon it if this issue can be addressed.
Thank you in advance.
Results 1 to 1 of 1
remove chroma from a digital video and add new color to the luma
By rudolf016 in forum RestorationReplies: 3Last Post: 24th Feb 2012, 11:11 -
Chroma/Color Bleed Issues In MPEG2-->XviD Conversion
By onesikgypo in forum Video ConversionReplies: 8Last Post: 25th Jun 2011, 21:11 -
x264 or other option for encoding Fraps output with no chroma subsampling?
By Cogitation in forum Video ConversionReplies: 12Last Post: 26th Feb 2010, 17:44 -
[color=red]how do you play region 2 dvds on this setup[/color]
By j821977 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2008, 14:58 -
[color=red]Huge annoying title[/color]
By JohnnyMalaria in forum TestReplies: 1Last Post: 1st Feb 2008, 10:47
