I'm full of "help me!" requests this week, I guess.
I'm looking to see if there's a recommended program out there that'd allow capturing a still shot from a video or DVD playing on my computer (using Windows Media Player and some added codecs).
I've tried using the old "set WMP to its lowest performance setting" and then trying "print screen" but that doesn't work.
Any other suggestions?
Thanks.
Anything other than Windows Media Player, perhaps?
You might try the screenshot abilities of Media Player Classic HomeCinema, or VLC. Many of the other third-party players probably also have screenshot-capturing ability, but I haven't really tried any other players.
If cameras add ten pounds, why would people want to eat them? -
when all else fails there is always the print screen key on the keyboard. Then just fire up Paint and paste. Crop and save - voila!
I'll take a look at this "VLC" and find out what it's all about. Thanks guys. Guess it's a player with better features? (Maybe it'll also solve the problem I've had in the last month or so with WMP no longer playing .flv even with additional codecs. Oh, it plays them...without audio. Don't know what happened. Been having to convert every .flv to another format before it can be heard.)
If the print screen method does not work it is due to the way that your video card is using the overlay. So you end with a green screen where the video should be. A 'fix' to this is to go to the troubleshoot properties of your display settings - right click on desktop/properties/settings/advanced/troubleshoot and move the slider to the left.
That 'fix' could cause display issues so it really is a last resort. VLC is a one-click solution. Media Player Home Cinema will also do it but I have found issues with anamorphic dvds so you do not get an image with the correct aspect ratio. There may be a fix within the program for this but I have not persued it. VLC does it at the correct aspect ratio with just one mouse-click and no copy/pasting etc.
How To capture video shot in both sp and lp on the same dvc
By ishwinderjauhar in forum Capturing and VCRReplies: 0Last Post: 13th Jul 2011, 08:40 -
automatic shot by shot video cutter
By monks19 in forum EditingReplies: 4Last Post: 26th Oct 2009, 19:17 -
AVI2DVD will not capture snap shot
By dkinney in forum Video ConversionReplies: 3Last Post: 18th Apr 2008, 18:43 -
Unable to capture screen shot for background
By Cole in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 17th Jan 2008, 14:53 -
Wedding video camcorder dvd-rw accidentally shot over.
By jim s in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2007, 10:03
