Hello, i downloaded breaking bad s04 e01 and when i click on the file - properties to see what kind of file it is, it just says file. I tried to play it with dix and it doesnt work, it works with Windows media player after i get some kind of message that says it doesnt recgonize file or something but it can still play it.
But i want it to play it on PS 3 so how do i do that because it doesnt recgonize it either ?
Please help me. Sorry for the stupid question.
How do i find out what kind of file it is ?
Well, WMP is a piece of crap so the fact that it doesn't play the file means nothing. You could try installing VLC, which is free. If it's playable, VLC should be able to play it.
I wouldn't discount the possibility that the file is corrupted and won't ever play. If you got it off some torrent site you should be aware that all it takes is one person to have a problem with their hard drive after getting the file and they'll start sending out a corrupted version to everyone. It's not common but it does happen. Also, Hollywood has been known to deliberately place corrupted versions of files on torrent sites so that could be going on. -
I 2nd the mediainfo suggestion. d/l and run it on the file in question. export results as a text and then upload (attach) it here and perhaps one of the gurus here can look at it and take it from there. also, as jman98 suggests/suspects, try a different player and/or it may be corrupted.
Thank you for help guys, i tried the mediainfo before it says matroska.
Anyway i got it to work on PS 3 with PS 3 Video 9.
Its now mpeg4, and i would like to ask how do i merge subtitles on it without losing quality ? AVIAddXSub doesnt work.
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 15:24 -
How to demux subtitles from MPEG4
By merunka in forum SubtitleReplies: 3Last Post: 9th Jul 2010, 02:09 -
Mpeg4 to ?
By acestu in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2008, 21:45 -
Mpeg4 editing
By Commando7 in forum EditingReplies: 2Last Post: 3rd Dec 2007, 11:38 -
Getting DVDs to MPEG4-SP or MPEG4-AVC
By WoWchamp in forum DVD RippingReplies: 7Last Post: 30th Oct 2007, 23:47
