I love PotPlayer to capture video from input source but i have this problem
Is there any way to record videos using RGB Lossless, coz it doesnt appear in codec list and i really want to use it
I have Camtasia properly installed (in order to use the registered version of the codec) and codec is installed in 32 and 64bit version. I'm using PotPlayer x86
Any ideas
Thanks!![]()
Windows has two separate video subsystems: VFW and DirectShow. Codecs for one can't be used with the other. Since you have 64 bit Windows this is further complicated by the fact that 32 bit programs can't use 64 bit codecs and 64 bit programs can't use 32 bit codecs. So you have four video subsystems. In addition to that, any program can use its own internal codecs. And if you use XP mode you have two more 32 bit VFW and DirectShow systems. All of which cannot see each other.
Lossless codec did THIS to a video i made...help!
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2011, 06:49 -
Need a lossless codec that works in Windows 7/Vista
By LSchafroth in forum EditingReplies: 13Last Post: 25th Nov 2009, 10:12 -
the decompression codec cannot decompress to an rgb format
By flemmo in forum Video ConversionReplies: 11Last Post: 19th Jul 2009, 09:23 -
lossless codec for QT pro, vegas platinum
By benrtc in forum Video ConversionReplies: 1Last Post: 6th Apr 2008, 02:43 -
Lossless Audio Codec Comparison '07
By Tab in forum AudioReplies: 8Last Post: 3rd Jul 2007, 01:08
