Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Sep 2010
    Traverse City, MI
    I have a Sony DRU-810A CD drive which I would like to install in a Dell Inspiron 580, but the connectors don't match.
    Is there some sort of adapter I could use?
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Why bother with a CDR drive when you can get a new SATA DVDR drive for $20?
    The DRU-810 has an EIDE connetor.
    If your mobo lacks EIDE you can add a PCI card such as Promise tx series or older Ultr66. Get a used one on ebay.
    http://www.kiva.org/about
    Sep 2010
    Traverse City, MI
    The DRU-810A is actually a cd/dvd combo . . I accidentally broke the tray on the installed drive and I still have the Sony from my other computer . . was hoping maybe there was just a cheap adapter I could use. Since that's apparently not an option, probably better to buy a cheap SATA drive, as you suggest. Thanks so much for the help!
  4. Member DB83's Avatar
    Jul 2007
    I believe that the DRU-810 is a dvd drive.
    But I tend to agree with my friend above that by the time to invest in adpaters/connectors you could have obtained a drive that is suitable for the connectors you already have.
    BTW You have not exactly helped getting a full answer to your question having failed to advise what actual connectors you have for both power and interface
