I use MeGUI to convert MKV's with DTS/AC3 to AAC sound in the MKV. I use the one click encoder and leave the video unconverted.
More often than not, it will begin by extracting the audio track successfully and will then proceed to pre-processing, where it will hang indefinitely. It doesn't go anywhere. It's been left for hours with no results. Normally it pre-processes for a couple seconds max, but not in this case.
Any ideas what the problem is? I've had quite a few successful runs at this, so I can't nail down what the problem is exactly. As of right now it just seems to be random, but then I don't know much about MeGUI as I'm new.
Any help is greatly appreciated.
Update: it seems that AC3 and DTS files don't work equally when it's the same file. I had an MKV with DTS that I converted to AC3 using Popcorn, and it didn't work either. Makes me think it's something to do with something inside the file.
Help with MeGUI and audio
By ratskie in forum Video ConversionReplies: 0Last Post: 21st Aug 2011, 15:05 -
Megui only processing 1/3 the number of frames
By capvid0429 in forum Video ConversionReplies: 1Last Post: 3rd Jan 2011, 19:28 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
can i rip DVD with pre-stated audio delay in ms (active or negative)
By deejay.2001 in forum DVD RippingReplies: 1Last Post: 29th Sep 2008, 04:09 -
Megui Audio Conversion
By dark_guard in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2008, 09:28
