  1. How can I capture a video from a video card (for example, a Blackmagic card), and then stream it to some kind of server for distribution? I prefer it to encode to MPEG-4 H264.
    Thanks.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    What is the video source?
    Stream SD like Ustream?
    http://www.kiva.org/about
  3. The video source is a Blackmagic card or any other DVB-S card (I don't care to buy one).
    I want it to capture the video feed from the card and then encode it to MPEG-4 H264. Right now, I need it in normal SD.
  4. Member edDV's Avatar
    Mar 2004
    Consider the Black Magic ATEM Television Studio which takes HDMI or SDI in and hardware encodes to h.264.
    http://www.blackmagic-design.com/products/atemtelevisionstudio/
    http://www.blackmagic-design.com/media/1528565/ATEM_Operation_Manual.pdf
    This could then feed a Viewcast Niagara or Telestream Wirecast software for stream upload to a service like Justin TV.
    http://www.viewcast.com/products/niagara-systems
    http://www.telestream.net/wire-cast/overview.htm
    Or you could just feed DV over IEEE-1394 (Firewire) direct to the Wirecast software.
    http://www.telestream.net/wire-cast/features.htm
  5. Can't I do it with FFmpeg or similar software? I prefer it because the source will probably be satellite feed (using DVB-S card).
