  1. getting error on mp4 conversions
    FFmpeg version SVN-r21363, Copyright (c) 2000-2010 Fabrice Bellard, et al.
    built on Jan 21 2010 14:46:42 with gcc 4.1.2 20080704 (Red Hat 4.1.2-46)
    configuration: --enable-gpl --enable-version3 --enable-nonfree --enable-shared --enable-libmp3lame --enable-libfaad --enable-libfaac --enable-libvorbis --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopencore-amrnb
    libavutil 50. 7. 0 / 50. 7. 0
    libavcodec 52.48. 0 / 52.48. 0
    libavformat 52.47. 0 / 52.47. 0
    libavdevice 52. 2. 0 / 52. 2. 0
    libswscale 0. 9. 0 / 0. 9. 0
    [flv @ 0x153983b0]Estimating duration from bitrate, this may be inaccurate
    Seems stream 0 codec frame rate differs from container frame rate: 1000.00 (1000/1) -> 25.00 (25/1)
    Input #0, flv, from '/httpdocs/hwdvideos/uploads/originals/r26mwxzrinqbaf.flv':
    Metadata:
    duration : 13
    width : 480
    height : 360
    videodatarate : 781
    framerate : 25
    videocodecid : 2
    audiodatarate : 206
    audiosamplerate : 44100
    audiosamplesize : 16
    stereo : true
    audiocodecid : 2
    encoder : Lavf52.82.0
    filesize : 2048757
    Duration: 00:00:13.04, start: 0.000000, bitrate: 1120 kb/s
    Stream #0.0: Video: flv, yuv420p, 480x360, 800 kb/s, 25 tbr, 1k tbn, 1k tbc
    Stream #0.1: Audio: mp3, 44100 Hz, 2 channels, s16, 320 kb/s
    Warning: not compiled with thread support, using thread emulation
    Unknown encoder 'libx264'
    [flv @ 0x18e3a3b0]Estimating duration from bitrate, this may be inaccurate
    Metadata:
    duration : 13
    width : 480
    height : 360
    videodatarate : 781
    framerate : 25
    videocodecid : 2
    audiodatarate : 206
    stereo : true
    audiocodecid : 2
    filesize : 2048757
    [flv @ 0x1f5e43b0]Estimating duration from bitrate, this may be inaccurate
    Metadata:
    duration : 13
    width : 480
    height : 360
    videodatarate : 781
    framerate : 25
    videocodecid : 2
    audiodatarate : 206
    stereo : true
    audiocodecid : 2
    filesize : 2048757
    [flv @ 0x1955d3b0]Estimating duration from bitrate, this may be inaccurate
    Metadata:
    duration : 13
    width : 480
    height : 360
    videodatarate : 781
    framerate : 25
    videocodecid : 2
    audiodatarate : 206
    stereo : true
    audiocodecid : 2
    filesize : 2048757
    .flv is fine
    looked around and discovered that hwd now uses lib264 how do i tell if I have libx264?
    I have ssh access
  2. looks like you didn't compile with libx264
    it should say --enable-libx264 in the configuration line if it's enabled
  3. thanks for quick reply but still not sure if I have lib264 as when i do it on another server the code works
  4. thanks for quick reply but still not sure if I have lib264 as when i do it on another server the code works
