okay still learning not sure which way is the best way to go the space is no concern for video files i am trying to set up a media library on my htpc using media browser.should i just stick with the M2TS files or remux to MKV.just trying to find out which way is the best.i have been trying the remux mkv.guide but i am have some playback issues.so any help would be grateful. thanks
Results 1 to 10 of 10
okay tried this seems to work well i still have some play back issues. i am not sure is there a certain requirement in playing larger files. suppose to playing smaller files. the files i have are 20gig and above but i read where some people are shrinking down to 13gigs and lower.
my specs are ( windows 7 pro 64bit
( mob asus p5p43td/usb3
( cpu intel core2 quad q6600 @ 2.40
( corsair memory 8 gigs of ddr3 1066
( 50 gig ocz vertex ssd
( amd radeon 6450 video card
( 5-2TB HDD
( my receiver is a denon avr591
( my tv is a samsung 55 led (un55b7000
i have more memory purchase and is on the way and also a newer video card. but any help would be appreciated. -
I have an Reveo which only as an Atom Cpu and Cuda video and it plays 1080p fine .
which player are you using. give Media Player Classic Home Cinema ago. I use this in conjunction with Shark007 codec packCHEERS GARRY -
I would give Media Player Classic Home Cinema ago I have had problems with VLC and blu-ray. Media Player Classic Home Cinema needs to be set up so it uses the correct codec but as I said before my Atom plays everything I chuck at it.
CHEERS GARRY
.M2TS to .MKV
By cjbrown80 in forum Video ConversionReplies: 2Last Post: 18th Aug 2011, 20:34 -
Why convert m2ts to mkv ?
By dude905 in forum Video ConversionReplies: 5Last Post: 31st Jul 2011, 09:17 -
.MKV to .M2TS
By rajsharma714 in forum Video ConversionReplies: 3Last Post: 3rd Jun 2010, 09:54 -
Blu-ray backup/playback problems (mkv, m2ts, ffdshow, mkv splitter)
By Pyrophoric in forum Video ConversionReplies: 0Last Post: 3rd Mar 2010, 10:26 -
M2TS to MKV
By mblanco2000 in forum Video ConversionReplies: 4Last Post: 11th Feb 2010, 12:27
