Results 1 to 12 of 12
    Feb 2010
    Thailand
    Q: Why I convert my AAC to AC3?
    A: My home theater can decode AC3 to 5.1 speaker. It cannot decode AAC directly.
    Q: What is the advantage of this method?
    A: This method use only 2 free tools: 1. Nero AAC decoder and 2. Aften
    It don't require big .WAV file as intermediate (big file require time to write/read to/from Harddisk. It read AAC file and send wav stream to aften on the fly.
    Heres how:
    1. Download and put Nero AAC decoder and Aften to same folder of your choice.
    2. Create batch file containing:
    NeroAacDec -if %1 -of - | aften -readtoeof 1 - %1.ac3
    3. Create a short-cut to this batch file.
    4. Drag and drop your AAC file to this short-cut.
    Another good thing about NeroAacDec is, it can demux AAC from .mp4 on the fly, so if you have movie.mp4, you can drag and drop it to the short-cut, it will produce movie.mp4.ac3 for you. There is no need to manually demux AAC out of movie.mp4 before use.
    Note: I ran into a problem once, NeroAacDec connot decode my mp4, so I use YAMB to make make it good mp4. Now NeroAacDec and decode it.
    Feb 2009
    i have found this to help with other formats & ac3 in supported.
    http://winff.org/html_new/downloads.html
    hope it helps
    Feb 2010
    Thailand
    There are surely more than one solutions to a problem.
    Thanks wrathofbod, for pointing out an alternative.
    Anyone who have other method, please feel free to add here in this guide.
  4. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
  5. Originally Posted by newyear1967 View Post
    Heres how:
    Hi thanks for this method.
    It seems very easy. I followed it as per your instructions but I am getting only a AC3 sound file created and no video with it. Can you help me, what am I doing wrong?
  6. Originally Posted by Video-Pal View Post
    Dude, he's only converting the audio.
  7. Member dragonkeeper's Avatar
    Jul 2003
    Have you considered using ffdshow to convert the audio on the fly? The signal is passed as AC3 to the receiver over the hdmi cable (it can also be passed over spdif cable).
    Murphy's law taught me everything I know.
  8. Originally Posted by chowmein View Post
    Thanks, yes I did realize my stupid mistake within half and hour of writing that message, anyway I completed it successfully with the help of My MP4 Box . Thanks again.
    Feb 2010
    Thailand
    Yes. Thank you. I'd like to know how.
  10. Sorry to dig up an old topic, but I'm really tearing my hair out over this. Whenever I drag my aac files to the shortcut, the window opens, but nothing else happens, it just doesn't do anything. It does work as it should with mp4-files, so my batch file seems to be set up right. Did I misunderstand something?
    Jan 2007
    Canada
    aacDECdrop? It says it's FAAD2-based AAC/MP4 drag'n'drop frontend.
    Thoughts?
  12. Member wulf109's Avatar
    Jul 2002
    TFM Audio Tool,I've used it many times to convert AAC to AC3.
