    Oct 2009
    Hi. I bought an in-dash DVD player for my car a while back. It has an SD card slot and plays Divx files, and I wanted to load some videos up onto it. The advertised resolution is really strange, apparently it's 1440x240. That obviously doesn't seem right. I divided 1440 by 4 and came up with 360x240. Whether that's right or not I don't know, but it seems a lot more reasonable. What would be the reason for that odd resolution?
    Question #2: I have some video files in DiVX/XViD format that I want to reconvert to smaller files (still in DiVX) closer to the native resolution of my player (mainly just to cut down on file size so I can fit more onto my SD card). What would you guys suggest would be the easiest/fastest way to go about that, and what resolution should I aim for? I've been out of the loop for so long with conversion tools and whatnot. Any help would be appreciated.
    May 2011
    Indonesia
    Regarding to this ... please give FactoryFormat a try.
    It's simple ... and the important is it is a FREEWARE
    The newesy version that I know is 2.70.
