    Mar 2011
    840 UNITED STATES
    hello all i am using the (How to rip a Blu-ray disc and remux it to MKV) guide and i am having some play back issues.the movie may freeze or stop and stutter or even play slow and sometimes be out of sync. i known this sounds like a lot.but dose anyone have any ideas. my main go is to take a blu-ray file and keep the original file size with the hd audio.thanks
    Feb 2004
    Australia
    1: Fill in computer specs
    Are you converting the audio ... in the guide there have been a few posts by others where audio sync has been an issue ... this can lead to playback issues.
    Mar 2011
    840 UNITED STATES
    the computer i rip with or play the movie on.
    no i am not converting all i do is use the tsmuxer to separate and leave out the tracks and subs and then merge back together.
  4. Try using Clown_BD instead of tsMuxer to extract movie-only. If there are any problems in the source files, such as multiple m2ts files with sync byte missing, sync discontinuity, etc, tsMuxer will be unreliable. Clown_BD, OTOH, can correct such errors.
    Then continue as before with your procedure. Good luck.
    Pull! Bang! Darn!
    Mar 2011
    840 UNITED STATES
    Thanks I will give it try
  6. Originally Posted by Bjs
    What Bjs means is for you to enter your computer specifications (CPU, speed, RAM, OS, Video Card, etc.) in your profile.
    -drjtech
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
