I was trying to backup a movie with BD-Rebuilder BD-RBV03804 . The audio is perfect for half the movie then it is off, it does not match with the lips moving, in other words the volume comes a second or so later that the lips moving.
Any suggestions or ideas.
Thank you
You haven't provided much information. Such as:
Name of the movie?
Have you used BDRB before with success? (Maybe your configuration isn't right)
What you're using to rip the disc?
Okay, assuming inspect.exe (in the BDRB folder) says your configuration is okay, there are a number of possibilities:
1) Bad rip. Try again, and update your decryption program first.
2) The main movie is split into multiple m2ts files that aren't being joined properly.
3) The disc has a complex interactive java menu.
If #1 above doesn't fix the problem, you could try running ANYDVDHD or DVDFabPasskey in the background and extract main movie with Clown_BD. If Clown_BD works and BDRB is able to re-encode the output without the audio going out of sync, that would point towards either #2 or #3 or both.Pull! Bang! Darn! -
fritzi93, Thanks for responding.
I used DVDFAB. The movie is Aliens. I tested the ripped movie on my hard drive with VLC player and it is perfect.
As I did the inspect this is what I got:
- Windows Version: 6.1 [7601]
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: 1.11.96.14, Ok
- FFDSHOW: 3933, not recommended version
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "ffmpeg-mt": Ok
- BD Rebuilder v0.38.0.4, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
The thing that stands out is the FFDSHOW: 3933 and after that is says "not recommended version".
Could that have anything to do with the problem I'm having and if so what version should I use?
Thanks -
I updated the FFDSHOW, I tried ripping just the movie with DVDFAB and the using BD-Rebuilder after that to no avail. There is one section where the movie seems to skip in terms of the voice. It still out of sync.
Color Issue Post BD Rebuilder encoding
By Brett4u6 in forum Blu-ray RippingReplies: 0Last Post: 6th Jul 2011, 15:58 -
BD Rebuilder failure to extract audio issue
By fnord333 in forum Blu-ray RippingReplies: 8Last Post: 26th Mar 2011, 14:37 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 23:53 -
Audio issue when shrinking blu ray to dvd using BD-Rebuilder or DVD-Rebuild
By sharjohn in forum Blu-ray RippingReplies: 2Last Post: 1st Dec 2010, 13:36 -
DVD-rebuilder issue: DVD9 to DVD5 not working
By Hurre in forum DVD RippingReplies: 13Last Post: 1st Apr 2008, 19:46
