I have 7 video file, 4 about 12Gb, one 16.6, and 8.5, the last 10.9 I don't want the video quality to go down to much so I'd like for each file to fit on one DVD. My question is what should I convert it to, to archive that file size (4.37) and possibly keep the video ratio the same.
Also is there software online where it will give me a file estimate of file size after converting to that encoding type.
Generally, you can't further compress Blu-ray video by 3:1 or 4:1 without losing some quality. x264 will probably give the best quality (use a GUI front end like xvid4psp) but you'll end up with an MP4 or MKV file that won't play on a standard DVD player. I don't know what you mean by "keep the video ratio the same".
file size = bitrate * recording time
Use a bitrate calculator to determine what audio and video bitrates to use to get the file size you want. -
But its already done with x264 but the files are huge too big for a dvd or a dual layer. Oh yea when I said video ratio I mean aspect ratio.
Also these files are x264 but with a mkv ext. and I thought that x264 was for mpg 3 or 4
My VLC player gives me these codec details
Type: Video
Codec H264 Mpeg-4 AVC (part10) (avc1)
Language: English
Resolution 1920x800
Frame rate: 23.976215
Strean 1
Type Audio
Codec DTS Audio dts
Language English
Channels 3F2/LFE
Sample 4500Hz
Bitrate 1536kb/s
Which one can I slak off on and try and keep a High video quality
and I think its such a large file is because of the resolution and the DTS audio
am I right when I say that.Last edited by AndreL; 18th Jul 2011 at 16:10.
Someone might know more but it seems as though the mkv container can contain just about anything, it seems to be very versatile.
That's why the quality is only going to get worse. The video is already compressed with (arguably) the best compression codec.
That's just a matter of setting the AR flag when you encode.
x264 is an implementation of the MPEG 4 part 10 compression specification, also known as h.264 or AVC. MKV is a container (a way of organizing data within a file) that can contain audio and video compressed with any of a number of different codecs. The x264 encoder can output to MKV, MP4, FLV containers, or as a raw h.264 stream.
How to convert Blu-ray to standard DVD-Video (or MKV,MP4) using free tools
By Baldrick in forum User guidesReplies: 4Last Post: 22nd Oct 2015, 20:39 -
Blu ray to MKV / x264 stops
By Dragonfiii in forum Blu-ray RippingReplies: 4Last Post: 13th Sep 2009, 16:50 -
mkv, x264, and h.264 to blu-ray to play on PS3
By cyberpimp16 in forum Authoring (Blu-ray)Replies: 1Last Post: 14th May 2009, 14:58 -
Best way to convert/burn/play .mkv H.264 Blu-ray/HD DVD files on a Mac
By iMacMan in forum MacReplies: 7Last Post: 21st Mar 2009, 16:50 -
Blu Ray to MKV (.x264) - What is the compression?
By james_stewart in forum Blu-ray RippingReplies: 9Last Post: 7th Nov 2008, 05:58
