  1. I have a few MP4 files which are way too soft, even at max volume. Are there any basic apps that can normalize them?
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Post the log from Mediainfo on one of the files.
  3. General
    Complete name : I:\School-scicommANU\Climate Change Science\Module 1\M01_Lecture1_2010_vol.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 163 MiB
    Duration : 1h 14mn
    Overall bit rate : 306 Kbps
    Encoded date : UTC 2010-08-07 13:37:36
    Tagged date : UTC 2010-08-07 13:37:36
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=1, N=50
    Codec ID : avc1
    Duration : 1h 14mn
    Bit rate mode : Variable
    Bit rate : 165 Kbps
    Maximum bit rate : 2 049 Kbps
    Width : 800 pixels
    Height : 600 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 10.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.034
    Stream size : 88.5 MiB (54%)
    Language : English
    Material_Duration : 4484300
    Material_StreamSize : 103914139
    Material_FrameCount : 44843
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1h 14mn
    Bit rate mode : Constant
    Bit rate : 119 Kbps
    Channel(s) : 2 channels
    Sampling rate : 22.05 KHz
    Compression mode : Lossy
    Stream size : 63.6 MiB (39%)
    Language : English
    Material_Duration : 4484377
    Material_StreamSize : 66679268
