Does anyone have any advise when using the logo remover filter from MSU? I am trying to remove the date and time from a video i made wearing a camera hat. It's slow going. Here is the video. Maybe you can offer a suggestion on how to delete the date and time. I can input the correct date and time in each video i produce, but sometimes the date and time text file does not stay in the camera hat's folder. I know the logo remover can remove it. I just need to find out how to use the filter. The pdf'd instructions are not too clear.
The video is a very small recording inside a 7-Eleven store.
thanks for your help!
http://www.dropshots.com/sneezer#date/2011-07-16/19:57:59
Sorry, I'm not sure how suggesting that the video be cropped answered the question he asked. He asked how to use MSU Logo Remover. If you didn't have an answer to that, you should not have replied.
I will assume you have the plugin downloaded and in your plugins folder.
1. Start Virtualdub
2. Load your video
3. Select Video>Filters>Add and choose MSU Logo Remover.
4. In the dialog box, choose the attributes of your logo (transparent, opaque, etc). You will also notice that there are two passes required, the first one to analyze the video and the second to actually remove the logo. You will also note a TV image with check boxes to indicate where in the video the logo appears. Make your selections.
5. Hit OK to exit the filter's properties and then OK again to exit Video Filters dialog.
6. Hit File>Run Video Analysis Pass (Let it run)
7. Go back into filters and this time tick Second Pass
8. This time choose File>Save AVI
Notes:
- This post only covers the MSU Logo Remover filter, you have many other settings to be aware of, that are covered in other tutorials. This post assumes you know the general workings of Virtualdub. If you do not, it is recommended that you first view some basic tutorials first.
- Be sure if you are using multiple filters, that MSU Logo remover is the first filter in the list. If it is not, Virtualdub will crash.
- Be sure to set your video compression settings before saving the final AVI. If you don't, you will output an uncompressed video that could be many GB in size.
Hope this helps. -
Thank you for the suggestion! I will try that. It's been forever since i had been on this website. I will definitely attempt my first use of the logo remover.
thanks again!
VirtualDub crashes when using MSU Subtitle Remover :(
By ralf07 in forum SubtitleReplies: 1Last Post: 17th Mar 2012, 03:16 -
Help needed with MSU Subtitle Remover in VDub
By Lippy Lipstick in forum SubtitleReplies: 11Last Post: 5th Mar 2010, 09:03 -
MSU subtitle remover, the great lie!
By driva in forum Newbie / General discussionsReplies: 5Last Post: 27th Dec 2008, 20:37 -
frustrated with VDMOD and MSU sub remover
By volam in forum SubtitleReplies: 1Last Post: 7th Feb 2008, 09:45 -
virtual dub logo avi too big
By forchristians in forum EditingReplies: 5Last Post: 20th Sep 2007, 23:47
