  1. illusion Dictator
    Jul 2011
    In your Heart
    Ultra ISO creates the movie ISO [7.72 GB] without error, but when I try to load the ISO into Fair Use Wizard 2.9 (on the same PC) I get the error:
    "The DVD filesystem could not be loaded. >>>Invalid directory ICB"
    Fair Use also did not accept ISOs from DVDDecrypter (ver 3.5.4.0) & same msg shown to there.
    Does anyone know what's causing this?
    Pls, expert bro solve the prob
    Commercial DVD? Then you need something more up to date like dvdfab or anydvd.
  3. illusion Dictator
    Jul 2011
    In your Heart
    I have got the Answer, with my own experiment
    Just make bit change in the ISO file properties with UltraISO or Any.
    Open the movie ISO file with UltraISO > Properties > File System > Check only UDF box (Uncheck Joliet box)
    & then save.
    Enjoy
