Hi all.. i usually work with ac3... i cut, insert silence and stuff like that to sync my audio with different video sources (muxing)..
I usually use audition to do that but it converts everytime loosing quality..
i know that it's possible to split and join ac3 files with some command line tool (besplit for example) so i thought to create my application.. i insert the points where i have to cut or insert silence and with my code i launch besplit that cut and join the file...
but there is one problem.. i don't know how to create ac3 silence files of fixed length and bitrate...
i try tosearch but i don't find anything.. you know some simple command line tool to do that? thanks in advance
Edit .mkv file (split/join) - nothing works "properly"!!!
By The.King in forum EditingReplies: 19Last Post: 11th May 2013, 07:23 -
Trying To Create An Ac3 File W/virtualdubmod?
By jwmghf in forum Video ConversionReplies: 0Last Post: 18th Jun 2011, 16:46 -
Long silence in ac3 is mysteriously shortened when I author
By Genaugmen in forum Authoring (DVD)Replies: 0Last Post: 20th Aug 2010, 17:47 -
join & split m2t files
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 1st Dec 2008, 21:15 -
Can't join this movie that is split and already burned on dvd
By f-zer0 in forum EditingReplies: 3Last Post: 3rd Jan 2008, 22:21
