Hi there,
I've got a problem with meGUI. I've already searched many forums and pages but I couldn't find a solution.
I generally know how to use meGUI and I have a pretty good audio and video encoder installed. I render unprotected .VOB files to .mkv files with multiple audio files (languages) and everything works fine
-except for-
doubled scences.
In the final .mkv file all scences showing text that was translated into the other language will appear twice right after one another. That means I get the film title in language A for like 1 second, than the audio file will jump back and the film title will appear in language B for 1 second and so on.
How do i prevent this from happening in meGUI? Is there a way to cut out the doubled scences automatically with mkvmerge or a similar program?
Thanks in advance!
Wow, I can't believe I didn't think about that. -.-
Thank you very much, I'll try again right now. -
Ok, I solved it now.
If someone is having the same problem and if he uses DVD Decrypter as first or second programm,
go to "Tools|Settings",
then go to "File Mode"
and select "Multi Angle Processing"
Then choose you favored angle (order should be the same as audio files).
horizontal lines in x264 encoded dvd using MeGUI
By codemaster in forum DVD RippingReplies: 5Last Post: 9th Dec 2010, 06:48 -
MeGUI
By anirban in forum Video ConversionReplies: 4Last Post: 4th Dec 2008, 20:28 -
help using megui
By 3289275 in forum Video ConversionReplies: 2Last Post: 12th Oct 2008, 09:26 -
Megui, some problems withe encoded result
By boy69 in forum Blu-ray RippingReplies: 6Last Post: 30th Sep 2008, 17:16 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 18:55
