Was wondering if anyone could reocmmend to me the best and user friendly CD Jewel case cover designing software out there. I have been using Acoustica the past 5 years and have found now that it will not print the correct size covers with my new cases. Was wondering if anyone can reocmmend other software?
Thank you.
Best is subjective...
Try the free UnderCoverXP -
Maybe I am really missing something here big time and if so I would very sincerely like to be educated out of my ignorance, but I've used UnderCoverXP for years and I've yet to see any way to "design" anything under it.
I sure wouldn't buy it just for this, but if you have a copy of Nero with enough extras on it, one of the extras is a cover designing program. It's not too bad but I prefer Acoustica.
Not really understanding how Acoustica is failing you now unless you have bought some very non-standard cases. Have you tried contacting Acoustica about it? Maybe there's a way to adjust the size manually that they can tell you how to do and maybe with a little tweaking you can get it to work fine for your needs. -
To second the above, good ol' Nero Cover Designer works fine and you already have it if you have Nero, and Acoustica is a fine program that works well, but you might also want to try SureThing CD/DVD Labeler, which is now my favorite.
You should be able to adjust the template sizes in Acoustica under the Edit tab at the top of the window to make your labels fit,another good if slightly quirky label making software is Discus.
http://www.magicmouse.com/h_discus_detail.html -
Memorex Xpressit
http://www.memorex.com/en-us/Support/exPressit-Label-Design-Studio/
Verbatim DVD+R 100 pack vs. DVD+R single jewel case
By GSP_87 in forum MediaReplies: 6Last Post: 13th May 2011, 06:00 -
need a jewel case for microSD cards
By mrtunes in forum MediaReplies: 2Last Post: 19th May 2009, 08:42 -
DVD cover software
By Prot in forum MediaReplies: 6Last Post: 4th May 2009, 00:38 -
JPEG --> DVD case cover
By vanquish42 in forum MediaReplies: 27Last Post: 26th Dec 2007, 16:09 -
CD Jewel Case Inserts...best pricing?
By ChaunceyK in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2007, 15:10
