Hi Guys,
I understand there are problems with using Streamtransport now as sometimes it works and sometimes it doesnt. I have read this on a lot of places that the developers who built it have also kind of abondoned it, so there is no real point in using it as no one know when will it work and when not. Which is what even I experienced. Having said that it was a wonderful tool which would download even HD videos from URL's without any data or quality loss keeping the HD quality intact. Any other software which does the same job of downloading HD videos from URL's without any quality loss in the HD quality.
Please suggest me a substitute to Streamtransport.
Results 1 to 10 of 10
Replay Media Catcher or GetFLV. But they are not free though. Or else I think you have to manually use rtmpdump.
I used GetFLV there is definitely quite a bit of Quality Loss in the downloaded clip. Doesnt quite have the same quality as Streamtransport would give. Any other suggestions ?
I've had some success with StreamHijacker on streams that StreamTransport couldn't handle, but as always with free programs you'll just have to try it and see if it works with what you want to capture or not.
I have Real Player SP plus which allows you to open a URL in it and so you can play a video directly from the URL in Real Player and at that time it gives an option to download it to your desktop which finally gets downloaded in a folder in your C: But I am not able to figure out the same downloaded HD video when played in Realplayer stutters, there is a lag and there is a apparent loss in quality while playing it, it doesn't look HD. But at the same time if you open the downloaded HD video in VLC player plays it perfectly without any problems and loss in quality what is this strange phenomenon. Can anyone throw some light on this? The downloaded video is in the .MP4 format.
This Streamhijacker does it download a HD video without any quality loss ?
I don't know. I've only used it to get audio files that StreamTransport wouldn't touch. Is there a reason why you can't just test it yourself and see if it works at all and then see if you like the quality or not? If you'd already done that instead of wasting your time asking about it you'd already know if it does what you want or not.
I can certainly understand how it makes more sense to just blindly trust people you've never met and just assume that they see things exactly like you do rather than try something for yourself and see how it works. Not.
You got exactly FOUR suggestions (count them) so yes, it would certainly take about 5 million years of your time to download them all and try them. Yep, that's certainly impossible. Given your attitude I wish you the best, but I'm done here.
Can streamtransport save as an original mp4 instead of flv?
By yoda313 in forum Video Streaming DownloadingReplies: 4Last Post: 18th Jun 2012, 16:37 -
Looking for a mix of GetFLV and StreamTransport
By TrayVH in forum Newbie / General discussionsReplies: 0Last Post: 24th Apr 2011, 11:45 -
Is there a problem with the batch downloading feature for streamtransport?
By yoda313 in forum Video Streaming DownloadingReplies: 2Last Post: 26th Mar 2011, 06:43 -
Another tool besides StreamTransport to capture video from non tub sites?
By dread in forum Capturing and VCRReplies: 1Last Post: 21st Oct 2010, 00:47 -
Does Streamtransport have a practical simultaneous download limit?
By yoda313 in forum Video Streaming DownloadingReplies: 5Last Post: 31st Jul 2010, 18:56
