Results 1 to 10 of 10
  1. Member solarblast's Avatar
    Nov 2004
    N. California. USA
    I have a couple of DVDs that I copied from DirecTV, 60 min each. I plan to use excerpts for a class I'm teaching, but I'd like to reasonably remove the commercials, so I don't have to FF over them. Is there any too that might be helpful to this end? I'm using Vegas 9.0 on Win 7. Even knocking out 80 to 90% of the commercials would be helpful.
    DVD Shrink in reauthoring mode. Or edit the dvd vobs with mpg2cut2 or videoredo. Much easier then vegas...
  3. Member solarblast's Avatar
    Nov 2004
    N. California. USA
    Thanks. I'll check it out.
  4. Banned
    New York, US
    Aug 2002
    South Florida
    VideoRedo will do a fine job but, it's not free.
  6. Member solarblast's Avatar
    Nov 2004
    N. California. USA
    OK, I've been away for awhile and now an ready to try to edit a DVD. It's pretty simply constructed. I recorded a hour program from DirecTv, then created a DVD with my Panasonic DVR. When it comes up to view, a window appears with about 6 rectangles. One of the rectangles shows the first frame of the video. If I click on it, the video begins. Simple.
    I decided to try DVD Shrink 3.2. I watched a little of the beginners DVD Guide. It looks like shrink only is capable of re-arranging and selecting Titles, and creating a new DVD from them. What I want to do is go through the one hour program and edit out commercials. I see some choices above. Which will do what I want? I don't think shrink is going to work for me.
  7. Sure it can. Save out each segment one at a time with Start/End Frames function. Then reauthor all together.
    Pull! Bang! Darn!
  8. Member solarblast's Avatar
    Nov 2004
    N. California. USA
    As far as I can tell, there is one Title (segment?) and one Menu section. I displayed them with Re-Author.
    There's some sort of play window in the bottom left, but it does not seem to operate smoothly. I can sort of play things, mostly the menu, but a red square above the window appears. I guess I'm supposed to press it to record, but I see no way to edit anything, just select Titles and move them into an area on the left side of the screen.
    See <http://www.dvdshrink.info/reauthor_basic.php>, and press Next about five times, and you will see what's happening. They move title1 to the DVD Structure area, the another.
  9. Member solarblast's Avatar
    Nov 2004
    N. California. USA
    If all else fails, I can play the dvd on my portable dvd player, then pipe it into my video camera. From there into the PC, and Vegas. An hour of elapsed time.
  10. Member RogerTango's Avatar
    Nov 2007
    I have used it, does a GREAT job, pretty easy to use and worth the money.
    Andrew
