Hello!
I'm attempting to decode video that I have on an internal buffer(actually a circular mutex, as other things are also using this data). My internal buffer is a one to one copy of what I'm receiving over UDP from VLC streaming an mpeg2 file.
I have created a function: ReadData which I pass to avio_alloc_context, and it gets called properly when I do that. Then, I continue along just like how I did on my test app(which actually opened "UDP://127.0.0.1:4567" and worked successfully). However, when I get to av_read_frame() it becomes apparent that my AVFormatContext is not getting fully populated by avformat_open_input(). I'm not sure which piece specifically I'm missing, but when I call av_read_frame() the program exits.
My code(keep in mind that this is a work in progress and a lot of this will get cleaned up when I get it working):
And, for safety's sake here's my read function:Code:pCodecCtx = avcodec_alloc_context(); pAVFormatCtx = avformat_alloc_context(); AVProbeData probeData; probeData.filename = ""; int bufSize = 1024*8; unsigned char *buffer = (unsigned char*)av_malloc(bufSize*sizeof(unsigned char)); bool probed = false; if(InternalReadMethod(buffer, bufSize) >= 0) { probeData.buf = buffer; probeData.buf_size = bufSize; pAVInputFormat = av_probe_input_format(&probeData, 1); pAVInputFormat->flags |= AVFMT_NOFILE; pAVInputFormat->read_header = NULL; pAVFormatCtx->iformat = pAVInputFormat; probed = true; } pAVIOCtx = avio_alloc_context(buffer, bufSize, NULL, this, ReadData, NULL, NULL); pAVIOCtx->is_streamed = 1; pAVFormatCtx->pb = pAVIOCtx; if(!probed) { pAVInputFormat = NULL; pAVFormatCtx->iformat = NULL; } printf("Opening input buffer"); inputOpen = avformat_open_input(&pAVFormatCtx, "", pAVInputFormat, NULL); if(inputOpen == -1) { printf("couldn't open input buffer"); return -1; } int videoStream = -1; for(int i = 0; i < pAVFormatCtx->nb_streams; i++) { if(pAVFormatCtx->streams[i]->codec->codec_type == AVMEDIA_TYPE_VIDEO) { videoStream = i; break; } } if(videoStream > -1) { pCodecCtx = pAVFormatCtx->streams[videoStream]->codec; pCodec = avcodec_find_decoder(pCodecCtx->codec_id); } else { //Assume MPEG2 for now pCodec = avcodec_find_decoder(CODEC_ID_MPEG2VIDEO); } AVPacket packet; int frameFinished; int numBytes; uint8_t *frameBuffer; if(avcodec_open(pCodecCtx, pCodec)<0) { return -1; // Could not open codec } // Allocate video frame pFrame=avcodec_alloc_frame(); // Allocate an AVFrame structure pFrameRGB=avcodec_alloc_frame(); if(pFrameRGB==NULL) { return -1; } // Determine required buffer size and allocate buffer numBytes=avpicture_get_size(PIX_FMT_RGB24, pCodecCtx->width, pCodecCtx->height); frameBuffer=(uint8_t *)av_malloc(numBytes*sizeof(uint8_t)); // Assign appropriate parts of buffer to image planes in pFrameRGB // Note that pFrameRGB is an AVFrame, but AVFrame is a superset // of AVPicture avpicture_fill((AVPicture *)pFrameRGB, frameBuffer, PIX_FMT_RGB24, pCodecCtx->width, pCodecCtx->height); while(av_read_frame(pAVFormatCtx, &packet)>=0) { ... }
If anybody can tell me what I've done wrong, or even just point me to someplace that could explain in more detail how I should be setting up the interface between my internal buffer and ffmpeg I'd be deeply indebted to you!Code:int ImageInterface::ReadData(void *opaque, uint8_t *buf, int bufSize) { if(((ImageInterface*)opaque)->InternalReadMethod(buf, bufSize) >= 0) { return bufSize; } else { return -1; } } int ImageInterface::InternalReadMethod(uint8_t *buf, int bufSize) { return(myCircBuff->peekData(buf, bufSize));//returns 1 on success, -1 on fail }
Thanks!
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 04:11 -
ffmpeg gives buffer underflow
By zkab in forum Video ConversionReplies: 2Last Post: 9th Aug 2010, 03:45 -
Disable internal ffmpeg codecs?
By McAlsop in forum Video ConversionReplies: 1Last Post: 23rd Sep 2009, 01:12 -
Programming FFMPEG (Visual Basic)
By Ace-Of-Spades in forum ProgrammingReplies: 4Last Post: 9th Oct 2007, 06:18 -
programming?
By php111 in forum ProgrammingReplies: 6Last Post: 7th Aug 2007, 07:52
