Folks,
I'm a newbie - today, I downloaded ffmpeg-git-5d4fd1d.tar.bz2.tar and compiled it in cygwin as per the instructions on
http://ffmpeg.org/general.html#SEC24
Just did configure/make/make install
I got an error when trying to encode yuv2mpeg2 and encapsulate in mpegts (see below).
I must have missed something during the compile process because the command below works for precompiled static binary. Oh, I need the source code because I had to change MAX_SLICES in a header file for another thing I was doing (h264 decode) so I would rather use the source.
Thanks for your advice in advance.
videoBandit
ffmpeg -s 1280x720 -r 30 -i Eighth_Ave.yuv -f mpegts -vcodec mpeg2video -pix_fmt yuv420p -b 3000000 -an -r 30 -s 1280x720 -vstats_file ./logs/Eighth_Ave_30fps_3mbps.stats ./mp2/Eighth_Ave_30fps_3mbps.ts
ffmpeg version 0.7, Copyright (c) 2000-2011 the FFmpeg developers
built on Jul 13 2011 10:59:22 with gcc 4.3.4 20090804 (release) 1
configuration:
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 7. 0 / 53. 7. 0
libavformat 53. 5. 0 / 53. 5. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 24. 3 / 2. 24. 3
libswscale 2. 0. 0 / 2. 0. 0
[rawvideo @ 0x16f06f0] Pixel format was not specified and cannot be detected
[rawvideo @ 0x16c65b0] Could not find codec parameters (Video: rawvideo, 1280x720)
[rawvideo @ 0x16c65b0] Estimating duration from bitrate, this may be inaccurate
Eighth_Ave.yuv: could not find codec parameters
Duh, nevermind -
I erroneously had the pix_fmt flag attached to the output file - it should be attached to the input file. Made the change and it works now on my compiled version. Here's the correct command. This thread can be closed.
-videoBandit
ffmpeg -s 1280x720 -r 30 -pix_fmt yuv420p -i Eighth_Ave.yuv -f mpegts -vcodec mpeg2video -b 8000000 -an -r 30 -s 1280x720 -vstats_file ./logs/Eighth_Ave_30fps_8mbps.stats ./mp2/Eighth_Ave_30fps_8mbps.ts
configuration:
[rawvideo @ 0x19b65b0] Estimating duration from bitrate, this may be inaccurate
Input #0, rawvideo, from 'Eighth_Ave.yuv':
Duration: N/A, start: 0.000000, bitrate: N/A
Stream #0.0: Video: rawvideo, yuv420p, 1280x720, 30 tbr, 30 tbn, 30 tbc
File './mp2/Eighth_Ave_30fps_8mbps.ts' already exists. Overwrite ? [y/N] y
[buffer @ 0x19e6de0] w:1280 h:720 pixfmt:yuv420p tb:1/1000000 sar:0/1 sws_param:
[mpegts @ 0x19e6740] muxrate VBR, pcr every 3 pkts, sdt every 200, pat/pmt every 40 pkts
Output #0, mpegts, to './mp2/Eighth_Ave_30fps_8mbps.ts':
Metadata:
encoder : Lavf53.5.0
Stream #0.0: Video: mpeg2video, yuv420p, 1280x720, q=2-31, 8000 kb/s, 90k tbn, 30 tbc
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop, [?] for help
frame= 1326 fps=104 q=14.3 Lsize= 46795kB time=00:00:44.16 bitrate=8679.6kbits/s
video:43265kB audio:0kB global headers:0kB muxing overhead 8.160041%
AVStoDVD: framerate= 0 detected
By mathmax in forum Authoring (DVD)Replies: 3Last Post: 3rd Jul 2011, 00:49 -
Converting Special Format 5248x608 Pixel
By macumsteiger33 in forum ffmpegX general discussionReplies: 2Last Post: 11th Aug 2009, 02:53 -
VBR Audio detected
By timmer545 in forum AudioReplies: 16Last Post: 31st Mar 2008, 11:17 -
No Matched Drive Detected.
By dannymichel in forum DVD & Blu-ray RecordersReplies: 14Last Post: 6th Feb 2008, 19:13 -
Camera Not Detected
By Poke598 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 25th Jun 2007, 12:39
