I recently brought a leather case that came with keyboard for tablet, the USB connects into the tablet but the tablet has only a mini USB port where can I find An Adaptor that will turn it from a regular USB into a Mini USB. The USB cable that came with the keyboard is built in it it's not removable.
Something like this http://www.monoprice.com/products/product.asp?c_id=103&cp_id=10314&cs_id=1031401&p_id=...seq=1&format=2
From monoprice should work.
I have to be honest though, I have a similar arrangement as you describe with a knock-off tablet and the adapter didn't work, though mine may be 4 pin instead of 5.
My tablet did come with a wired adapter that works fine with the case, but it's much bigger than this.
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
I ordered one from monoprice but one problem the one I got is a standard USB to going to a micro USB it needs to be a standard USB to a mini USB? It needs to to four pins Any suggestions
What do you mean as 'standard' USB? Monoprice may have what you need. Can you add a picture of what you have/need?
NO, But I talked to a tech at Coby and he told me that it needs to be a standard to mini USB adaptor but with four pins. Monoprice has one but It has five pins instead of four. My tablet is the Coby Kyros MID8024 unit If you want to know the kind of tablet I have.
okay so do you need this then
I just searched for that using the link that Des provided above
edit
looks like Des and I posted at the same timeDonadagohvi (Cherokee for "Until we meet again") -
or this http://www.cablesforless.com/Adapter-USB-B-Female-To-Mini-B-4-Pin-Male-P5963.aspx
look like they will work?
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 16:03 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 10:24 -
Sanyo WH1 - Mini HDMI to USB
By XFINITE in forum Newbie / General discussionsReplies: 0Last Post: 19th Oct 2009, 10:41 -
Cinergy 400 USB & pcmcia»USB 2.0 difficulties
By AEN007 in forum Capturing and VCRReplies: 0Last Post: 4th Mar 2009, 01:21 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 18:23
