hope i can explain this as i am female and not too tech savvy..just bought a samsung 22 inch tv( have an hdmi cable)..its a great pic, however the bottom and sides do not fully show up, no matter what size i set the pic..example, watching qvc, the left side which shows price and name of item is cut in half..as is the bottom of screen on fox, cnn etc. so i only see half of the announcements..have looked at manual and all the tv settings but i cant fix this..
Push the blue "P.SIZE" button on the remote until you get the correct picture. "Just Scan" should show the whole frame.
i;ve done that 100s 0f times..no luck..should add this tv connects to a cablevisoin dvr..
Make sure your cable box is set to output 16:9 at the HDMI port. And that it's not set to zoom or some such.
I don't know your cable box. But there's usually a setup button on the remote. Walk through the menus looking for video options. There may also be a format, screen size, or zoom option on the cable remote.
What does your TV say about the input resolution when you press the Info button on its remote? -
youre right, there is a way to size the pic with the remote..placed it on "full" and now i see all the script..thanks to all for solving this problem..
philips dvp5990 video cuts to black screen
By kolewrot in forum DVD & Blu-ray PlayersReplies: 8Last Post: 9th Dec 2009, 13:46 -
Does WinDVD8 gold or Plat allow full screen pic ?
By DBenz in forum Software PlayingReplies: 3Last Post: 13th Jan 2008, 20:51 -
There is a narrow line at the bottom of my screen.....
By gom in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 12:16 -
Cropping top, bottom or sides of video
By drtalk in forum Newbie / General discussionsReplies: 8Last Post: 7th Jul 2007, 15:27 -
Subs cover-up bottom of screen
By ProudAnselmo in forum SubtitleReplies: 3Last Post: 10th Jun 2007, 02:13
