  1. hello im new here but i downloaded PopCorn MKV and all the tools it needed and when i tried to convert a DTS mkv file to AC3 mkv then it gives me this messege:
    "unable to execute mkvmerge"
    and i downloaded it and it works alone fine and i dont know what to do...
    please help....
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    It looks like a filename confusion. The error indicates trying to open a very long name that omits the "\" in the original.
    Try renaming it to something much shorter, without spaces or periods or brackets in the filename or any folder names.
  3. Banned
    Freedonia
    Try renaming the directory under asaf to something very simple. I'd recommend only 1 word like maybe Rio without ANY additional characters like a dot. The long directory name seems to be confusing the program as AlanHK points out. Looks like all those dots in the directory name are too much for it. The name of the file itself should be OK I think.
  4. what if it doesn't work?
    edit: it worked thnakes a lot
