Is it possible to add delta frames in an existing file. I have an avi with a frame rate of 3 fps. The vidoe is jerky. Is it possible to set those 3 frames to be keyframes and have the compression codec generate delta frames. eg. IF i want to change the farmne rate to say 30 fps could i use the original three frames at intervals of 10 fames ? if so how. TIA
Results 1 to 1 of 1
AnonymousGuest
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Frame rate conversions: How to blend select frames in AVISynth?
By SDeC in forum Video ConversionReplies: 9Last Post: 23rd Jun 2010, 08:16 -
How do I edit the frame rate of a selection of frames in VirtualDubMod?
By manilow in forum RestorationReplies: 4Last Post: 21st Dec 2007, 22:12 -
By Alexstarfire in forum Video ConversionReplies: 35Last Post: 22nd Aug 2007, 13:34 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
