Does the TM 900 come with a hard copy users manual? I called Panasonic and got someone whose english was lacking and then B&H Photo. Panasonic said "yes," there is an instruction manual. B&H could not open the box and their info was there is no hard copy users's manual-just a pdf on the CD. I need a hard copy-not the pdf which I already have. Can an owner please clear this up for me?
Not having a printed manual is always a bummer. In your case if you can't obtain a printed manual you will have to print the PDF manual.
Thanks for the input. However, Crutchfield said they would print the manual for me, if I bought the camcorder from them. Their price was only $10.00 over B&H but, the printed manual is worth more than $10.00 to me.
i have HD video camera HDC-TM900p/pc and i cant by the USB connection to export my motion video to pc i gett this massage: "Videos in incompatible TV systems were removed from the import target"
what can i do?
, I have recently purchased a new Panasonic HDC-TM900 in USA Cam recorder but my system is European PAL TVs.
I have taken several sample movies and they play back fine on my home TV.
So now I need to edit them with the provided software HD Writer AE.03 software.
Ok so I followed the camera and software instructions, first connect my camera to the mains power then switch on the camera and then connect to the USB port.
Great, I got a choice of PC or Recorder on the camera screen.
OK course I chose the PC option.
The smart wizard opened and gave me a choice of PC or Disc.
Again, I chose the PC option.
Then a screen opened giving me a choice of Simple Copy or Selected Copy (I tried both but it makes no difference).
I then got a message that the Media is not in the source drive.
Saying “cause”
Media may have been rejected
“Remedial action”
Check Media is copied and insert into the F:/ drive correctly
Press ok
HD Write screen showed, so I clicked on the built in memory icon and guess what, all my movie footage showed, wow, I selected and pressed execute.
I got a message
Data copying to PC, start OK, select yes.
I then got “Message Video’s incompatible with TV system were removed from import target”.
Press OK.
Then, I got a message “Exit copy to PC wizard”.
I pressed Ok and poof everything was gone (but at least the files are still in my camera memory)
Does anybody know how to resolve this issue? As I stated above, I am extremely frustrated and was not expecting to have so many problems with such a highly rated camera.
Any help will be greatly appreciated.
Thank you
my computer display information
PCI\VEN_1002&DEV_9540&SUBSYS_21AE1458&REV_00\4&399 D3C6A&0&0008
ATI display adapter (0x9540), תואם ATI Technologies Inc.
ATI Radeon HD 4550
Panasonic HDC HS900
By Ravelco in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 17th Aug 2012, 16:40 -
Panasonic HDC-HS900
By MICHAR in forum Capturing and VCRReplies: 1Last Post: 5th Jan 2012, 23:02 -
Panasonic TM900 NTSC to PAL conversion...
By vkshatriya in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 3rd Oct 2011, 04:24 -
Panasonic HDC-TM55k, anybody using it?
By twister6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 26th Dec 2010, 08:04 -
Panasonic HDC-SD60
By jvidia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 16th Jun 2010, 08:33
