Hi,
I am using Applian Replay Media Catcher 4 to capture streaming video.
I want to transfer the files it saves onto a USB stick for play back on my Toshiba SD2010KB DVD player.
The manual says it supports DivX file format (with an extension of DIVX, XVID, AVI).
I have tried the 'convert to AVI (same quality)' option in Replay Media Catcher, assuming it will convert the .flv file its capturing.
I have downloaded some .avi's and they play fine.
I assume the .avi file the software is creating is not correct, is there a way to set up Replay Media Catcher correctly - or some other conversion software, and what settings should I use.
Thanks.
Look at the stick here and make sure you aren't doing anything on this list.
https://forum.videohelp.com/threads/290800-My-DivX-DVD-Player-can-t-play-my-avi-DivX-xvid-video
You might want to install a program like GSpot and look at your files that won't play as there are probably some settings on that list that those files have and it's keeping them from playing. You could also compare with files that do play and see what's different between them.
Which is better quality capture- DVD recorder or Hauppauge WinTV USB stick?
By akalsha in forum Capturing and VCRReplies: 9Last Post: 6th Mar 2012, 18:57 -
Which is better - usb stick vhs cap or hd-pvr cap + convert for vhs to dvd?
By yoda313 in forum Capturing and VCRReplies: 22Last Post: 22nd Dec 2011, 20:13 -
Watch DVD WITH Menus from Hard Drive and USB Stick
By Squirl1899 in forum Newbie / General discussionsReplies: 6Last Post: 4th Oct 2011, 13:25 -
Watch DVD on Fash USB Stick/Disk on Home Cinema
By mdagis in forum Newbie / General discussionsReplies: 4Last Post: 8th Apr 2010, 10:06 -
m2ts for PS3 on USB stick or DVD
By leopardx in forum Media Center PC / MediaCentersReplies: 2Last Post: 14th May 2009, 09:56
