Hello
I know next to nothing about video editing, and need to extract a segment from an MPEG4 video that, according to VLC, has the following features:
I first tried with VirtualDub 1.9.11, but I get an error when opening the file: "The file ... is of an unknown or unsupported file type."Audio: MPEG AAC (mp4a) @ 44100Hz
Video: H264 - MPEG-4 AVC (part 10)(avc1)
Next, I tried with AVIDemux 2.5.5, but when playing the segment in VLC, the video plays a bit faster than the original, and some cracking noises can be heard in the audio.
I don't know if it means anything, but the codec infos as returned by VLC are a bit different between the full original file and the short segment I build with AVIDemux:
http://img14.imageshack.us/img14/7738/avidemuxfullpart.jpg
Does someone know the cause for this problem, and a possible solution, whether with AVIDemux, VirtualDub, or any other Windows application?
And for my education, if there's a good newbie-accessible primer about audio/video that explains what the main issues are when playing/editing/converting files, I'm interested.
Thank you.
				Results 1 to 1 of 1
  Cracking Philips DVP3345By ringosshed in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Jan 2013, 08:57
  portable DVD player cracking sounds then hangsBy dzsoul in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th May 2009, 07:29
  Newbie help converting 1080p60 AVC Mpeg4 footage to BLuRay / AVCHD DiscBy nickb23 in forum Video ConversionReplies: 1Last Post: 14th May 2009, 10:20
  Computer question, what makes them encode faster, unrar faster etc.?By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 23:21
  Newbie question about the audio sounds of my PCBy jeanpave in forum AudioReplies: 5Last Post: 12th Sep 2007, 01:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
