Hello,
I recently tried editing certain scenes out of a blu-ray rip I have (in the form of an MKV).
The original file contained:
-1 AVC 1080p video stream
-1 DTS MA audio stream
-2 AC3 streams (Movie commentary)
-3 English VobSub subtitle streams (Movie, Commentary 1, Commentary 2)
-1 Arabic SRT subtitle stream (movie)
-Chapters
What I did was use the "splitting" function of mkvmerge to split the MKV into 5 parts, at certain timecodes. I then deleted parts 2 and 4 (which were the scenes I did not want), and attempted to join parts 1, 3, and 5 together.
Watching each part individually, I get no issues.
I then opened part 1 using mkvmerge. I then used the "append" function to add parts 3 and 5. However, this produces significant audio sync issues. The part of the new file that used to be part 1 (to which the other 2 were appended) is fine, no sync issues with any of the streams. However, after getting to the part where the join was made, everything loses sync with the video. The subs/audio streams are all in sync with each other, but the video comes a little earlier than it should be.
At both points where the join has been made, the video speeds up significantly for about a second, then reverts to the normal frame rate.
Any ideas what is going on?
I realise I've made quite a few sync issue topics recently, so apologies for the spamming.I'd greatly appreciate any advice you guys might have on this.
Thanks (again),
Odaik.
EDIT: Looking through the MKV again, it seems that there is indeed no sync issue in the first part, then the video is about 3.5 seconds ahead of the audio/subs after the first join, then this gap doubles to about 7 seconds after the second join.
Yes i have quite the same problem here
2 files, both 1.30 h long .h264 files with dts sound. i just want to combine them into 1 mkv file.
with tsmuxer i can sync audio/videostreams of the second part, but as soon as i watch the video, the playback stops at the point the second file should start for about 2 seconds, then it plays on, but with NO sound! i have to skip forward for about 5 seconds, then the video is playing on as if nothing happened. Audio/Video is synchronized.... i really dont get it, why is there a 2 second stutter in the playback?
edit: if there is an answer here somewhere else, i apologize, but i googled my problem and this topic seemed to be the most recent one for me, that is quite similar to my problem.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
Question about using "delay" in mkvmerge.
By Gothic Autumn in forum AudioReplies: 0Last Post: 13th Jun 2011, 21:30 -
Stripping & Appending / "engage use_codec_state" ... MKVmerge / splitMKV
By salinsky in forum SubtitleReplies: 2Last Post: 14th May 2011, 09:41 -
Seeking avisynth function for "blend-a-field" idea
By vhelp in forum EditingReplies: 2Last Post: 21st Sep 2008, 20:52 -
"Cannot append segment...", "Mismatch detected..."
By Ygramul in forum Newbie / General discussionsReplies: 2Last Post: 14th Jun 2007, 11:32
