Hello. I want to shrink a Bluray to BD25 but without Trailers included into the BD50.
But if i right Click on the mts part i cant "blank this item"
Of course you can't, that's not a feature of BDRB, nor of any other BD to BD program at this time. It's not implemented yet, although obviously the author intends to. That's why "Blank this item" is grayed out. With BDRB, it's all or nothing, everything or movie only. (Apart from deselecting unwanted audio and subtitle streams).
So whatever you want to remove, get rid of it *before* feeding it to BDRB. Possible alternatives are:
1) Clown_BD BD Copier, which will strip out top menu and movie. But it won't handle interactive java menus, so other than being able to select play from top menu, it's a near certainty that nothing else in the menu will work. (I've tested it, but haven't used it extensively).
2) Rip full disc, then remove unwanted items with BDEdit. That is a fairly daunting program, and again, java menus may be problematic. Consult a guide.
3) I believe it can be done with multiAVCHD, but don't expect it to be an easy job. Again, you'll need a guide.
It may be that some payware exists that can *easily* do exactly what you're asking, but I'm not familiar with any. Perhaps BDFix.
Here's what jdobbs has to say about it:
http://forum.doom9.org/showthread.php?p=1467663#post1467663Last edited by fritzi93; 12th Jul 2011 at 17:04.
Pull! Bang! Darn! -
Thanks. I have tried Clown_BD BD Copier which is a bit confusing. Looks like there are two possibilities.
1. Rebuilding a BD with tsmuxer
2. just a Copy??
the First option i dont want to use because i just want to strip the trailers. Or must i use THIS option to get my result?
If i use the second option (HDD Copy) and i have unchecked the *.mpls i dont want, they are still included into the burned Copy.
And...What does that mean (see attachment)? Do i have to uncheck 00022.mpls too? Or is Clown_BD BD Copier deselecting that? Thanks for your Help -
Use tsMuxer mode in Clown_BD BD Copier.
See this thread:
https://forum.videohelp.com/threads/330273-Clown-BD_BD-Copier?p=2045999Pull! Bang! Darn!
Finally got around to doing a full backup - how often do you do yours?
By yoda313 in forum Off topicReplies: 6Last Post: 31st Jan 2012, 23:10 -
BD Rebuilder FULL backup
By jedisinclair in forum Blu-ray RippingReplies: 1Last Post: 14th May 2010, 20:00 -
Does BD-Rebuilder Full Disc mode work?
By ronorkis in forum Blu-ray RippingReplies: 22Last Post: 1st Sep 2009, 05:12 -
Full Backup Mode in BD Rebuilder
By fjmr in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Jul 2009, 03:32 -
Full Backup into a USB hard drive
By edong in forum ComputerReplies: 3Last Post: 11th Sep 2007, 15:19
