Hi,
I've got this m2t file I have to encode in mp4 using ffmpeg. But when I do, it basically says I can't because the input and output have different frame rates.
Here's the line I use :
And here is the output I get :Code:-f mp4 -vcodec libx264 -r 29.97 -s 1920x1080 -aspect 16:9 -b 7000k -b_strategy 2 -bf 2 -cmp +chroma -coder 1 -flags +loop -flags2 +bpyramid+mixed_refs+dct8x8+wpred+fastpskip -g 30 -i_qfactor 0.71 -me_method umh -me_range 16 -partitions +parti8x8+parti4x4+partp8x8+partb8x8 -qcomp 0.6 -qdiff 4 -qmin 1 -refs 3 -subq 6 -threads 0 -trellis 0 -ab 192k -ac 2 -acodec libfaac -ar 44100 -async 1
The out put video plays extremely fast, although the sound seems okay.Code:FFmpeg version git-N-28606-g26d9a9c-Sherpya, Copyright (c) 2000-2011 the FFmpeg developers [mpegts @ 015ffb80] Invalid timestamps stream=0, pts=3600, dts=7200, size=54532 <Repetition> [mpegts @ 015ffb80] Invalid timestamps stream=0, pts=133200, dts=136800, size=64000 Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1) -> 25.00 (50/2) Input #0, mpegts, from 'C:\Input\50297_01.m2t': Duration: 00:34:08.04, start: 0.000000, bitrate: 26189 kb/s Program 1 Stream #0.0[0x44]: Video: mpeg2video (Main), yuv420p, 1440x1080 [PAR 4:3 DAR 16:9], 25000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0.1[0x45](eng): Audio: mp2, 48000 Hz, stereo, s16, 384 kb/s (hearing impaired) [buffer @ 04097f60] w:1440 h:1080 pixfmt:yuv420p [setdar @ 0162acc0] a:16/9 [scale @ 016bb770] w:1440 h:1080 fmt:yuv420p -> w:1920 h:1080 fmt:yuv420p flags:0x4 [setdar @ 0162acc0] w:1920 h:1080 -> dar:16/9 par:1/1 [libx264 @ 04058010] using SAR=1/1 [libx264 @ 04058010] using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 [libx264 @ 04058010] profile High, level 4.0 [libx264 @ 04058010] 264 - core 114 r1924 08d04a4 - H.264/MPEG-4 AVC codec - Copyleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac= e=6 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=12 sl ined_intra=0 bframes=2 b_pyramid=2 b_adapt=2 b_bias=0 direct=2 weightb=1 open_gop=0 weightp=0 keyint=30 keyint_min=16 scenecut=0 intra_refresh=0 rc_l 0 qcomp=0.60 qpmin=1 qpmax=31 qpstep=4 ip_ratio=1.41 aq=1:1.00 Output #0, mp4, to 'C:\Users\Me\Desktop\Video Test Results\50297_01.mp4': Metadata: encoder : Lavf52.103.0 Stream #0.0: Video: libx264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], q=1-31, 7000 kb/s, 2997 tbn, 29.97 tbc Stream #0.1(eng): Audio: libfaac, 44100 Hz, stereo, s16, 192 kb/s (hearing impaired) Stream mapping: Stream #0.0 -> #0.0 Stream #0.1 -> #0.1 Press [q] to stop encoding [mpegts @ 015ffb80] Invalid timestamps stream=0, pts=3600, dts=7200, size=54532 <Repetition> [mpegts @ 015ffb80] Invalid timestamps stream=0, pts=900000, dts=903600, size=24611 frame= 152 fps= 13 q=9882577.0 Lsize= 4649kB time=5.01 bitrate=7609.1kbits/s dup=67 drop=0 video:4456kB audio:186kB global headers:0kB muxing overhead 0.145619% frame I:6 Avg QP:18.73 size:140040 [libx264 @ 04058010] frame P:96 Avg QP:20.46 size: 27758 [libx264 @ 04058010] frame B:50 Avg QP:22.50 size: 21145 [libx264 @ 04058010] consecutive B-frames: 42.1% 34.2% 23.7% [libx264 @ 04058010] mb I I16..4: 2.6% 87.1% 10.2% [libx264 @ 04058010] mb P I16..4: 0.2% 4.8% 0.3% P16..4: 26.4% 9.4% 6.2% 0.0% 0.0% skip:52.6% [libx264 @ 04058010] mb B I16..4: 5.3% 14.2% 0.2% B16..8: 59.5% 8.2% 0.2% direct: 2.3% skip:10.0% L0:21.3% L1:65.5% BI:13.2% [libx264 @ 04058010] final ratefactor: 19.97 [libx264 @ 04058010] 8x8 transform intra:80.5% inter:57.2% [libx264 @ 04058010] coded y,uvDC,uvAC intra: 75.5% 68.2% 23.9% inter: 13.0% 17.1% 0.3% [libx264 @ 04058010] i16 v,h,dc,p: 37% 10% 33% 20% [libx264 @ 04058010] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 29% 10% 32% 3% 5% 5% 4% 6% 5% [libx264 @ 04058010] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 31% 12% 10% 6% 10% 10% 8% 8% 5% [libx264 @ 04058010] i8c dc,h,v,p: 49% 16% 30% 5% [libx264 @ 04058010] ref P L0: 78.2% 7.9% 13.9% [libx264 @ 04058010] ref B L0: 79.4% 18.5% 2.1% [libx264 @ 04058010] ref B L1: 97.1% 2.9% [libx264 @ 04058010] kb/s:7196.36
Can anyone see anything that could cause the problem ? Is it something FFmpeg will always have trouble with ? 'cause this is the first of a looong series of files I have to convert, and they're all similar. I don't see myself using any other tool right now, so I'd very much like FFmpeg to be able to process this.
Thanks in advance for your advice !
Regards.
 It's a difficult conversion. 25 and 29.97 are too far apart. What are you going to do with the audio ? The difference is too great for a simple speedup (~ 1.19x). It will sound like "chimpunks"
 Where are you getting extra frames? Are you going to add blended frames? add duplicate frames? add interpolated frames?
 This conversion would normally be done with a slowdown to 23.976 (audio & video) , with the same # frames, and telecined to 29.97
	I understand...
 What made me wonder is, I believe I remember having been able in the past to do such a conversion. Maybe with an earlier FFmpeg version. Though you make me doubt that now.
 Indeed, audio there has always been a problem.
 Would you say what I'm trying to do is outright impossible, very problematic, or just not something FFmpeg in particular does well ?
	I don't think ffmpeg (alone) has the appropriate tools or filters for this. I don't see anything in libavfilters that could do it. It's possible to do with avisynth + ffmpeg
 Why do you need it at 29.97 ? Is it for broadcast? No NTSC region stations use h.264
 If it's for web (flash), leave it at 25fps
  mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cutBy perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42
  Converting 60 fps to 30 fpsBy kelcey in forum EditingReplies: 11Last Post: 24th Jul 2008, 04:15
  How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fpsBy Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17
  Converting 23.976 fps to 29.97 fpsBy wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 19:26
  Converting 23.976 fps to 29.9 fpsBy zanos in forum Video ConversionReplies: 4Last Post: 13th Apr 2008, 10:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
