I am not a computer wiz but I have figured out that the reason my encoding with tmpgenc takes so long is because I have an amd-k6 333mhz processor. My motherboard is an asus. If I change out my motherboard to an asus a7v socket 462 with an althone xt 1800 how much will it speed up the process? Is this a good combation? Any takers on this question?![]()
Results 1 to 14 of 14
my Athlon 1.4Ghz takes about 8 hours with 2Pass VBR SVCD (but that was Saving Private Ryan, a 3 hour movie) so a VCD would probably be 3 or so hours and a normal 2Pass SVCD about 6-7 hours. your 1.8Ghz system would be about 30mins-60mins faster on each, depending on how well the movie can compress. i cant give u an exact calculation, hope that helps.
Video encoding is heavily CPU dependent. To oversimplify things: The more CPU muscle you have, the faster your files will be encoded.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Also remember that the XP has SSE instructions which the K6 doesn't have. Just upgrade, the difference will be noticable. What takes 8 hours on my 1 Ghz Athlon takes about 30 hours on my P3 450. You can see the difference
I have a question also about encoding speeds..
I have Amd 1,2, 512mb and using TMPGenc in WinXP. I takes about 6 hours to encode 45 minute material captured from VHS. I use DVD PAL VBR 4000kbs settings which are set by default in tmpgenc.
Is there any settings I could change in TMPGenc to make it faster? I don't mean the settings that effect the video but settings in the program itself. -
Yes, u can set the priority levels and disable viewable display when encoding should speed things up a few but not shure by how much.
Computers -
Using TMPGEnc Pro and SVCD VBR 1950kbps my dual P-III 850 is roughly one hour faster than my P4 1.7GHz using the same movie and settings.
right now i don't think any commonly available cpu is adequate for mpeg2 encoding. have any of u ever tried encoding 720x576 PAL MPEG2 (served from dvd2avi on highest quality decode) with highest motion search precision, floating point, and 1-1 noise reduction? it takes a loooong time, especially when u use vbr. but the quality is so excellent. it's better than a lot of commercial dvds i've seen.
can u try this and tell me how fast it goes on your pc? -
I tried one minute test clip with VBR 4000kbs and noise reduction and all the settings in max quality. TMPGenc showed 6 hours left so encoding whole 45 minute episode would have taken 200+ hours..
ADVISE: Use CINEMACRAFT!!! (CCE)
I own a K7 Athlon XP 1700+ @ 1800+, 256 PC133, 2 Maxtor 7200 rpm HDDs
2 Hour movie, VBR, 2-Pass, Máx. Settings + sound -> 3 hours top!
- TMPGenc offers better definition and color but more macroblocks and MUCH slower than CCE!
- CCE offers VERY fast compression, EXCELENT with motion, very good image quality.
PS: compress sound with another program (don´t use CCE)
PSS: compress video with CCE, sound with TMPGenc and then multiplex with bbmpeg 8) -
um, i don't think it takes 6hrs per minute, it's more like under an hour per minute on my old PII 350@392 with 384mb sdram with a sloooooowwww hard drive.
i think the time estimation is a very inaccurate for the 1st few minutes of encoding.
but it still takes 5-6 days to encode a whole movie....
cinemacraft won't work on my stinky old cpu because SSE is required.
it would be interesting to see the quality difference between encoders. i suppose i could try it on some pIIIs or p4s i have access to. -
A little less than $200 will get you an "Athlon XP1800+" and motherboard combo.
I will try the CCE today. Last night I encoded 1 hour 30 minutes survivor episode captured from VHS and it took 12 hours to encode. Without noise reduction and other extras.
What is the problem encoding audio in CCE? Now I use mpeg2 audio 384kbs and it's ok, at least with VHS captured stuff. I first export the sound from premier and do the noise reduction and normalize it in Cool Edit to make it clearer.
Encoding for faster streaming and MP4Box ?
By Miata in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2010, 19:57 -
Is encoding ur file unto another HDD faster?
By jones24 in forum Newbie / General discussionsReplies: 6Last Post: 15th Aug 2009, 17:45 -
How do I get faster encoding time from quad-core processor?
By nick101181 in forum Newbie / General discussionsReplies: 5Last Post: 26th Oct 2008, 14:54 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 22:21 -
Increasing Encoding Speed?? What Hardware makes it run faster?
By sandman423 in forum Newbie / General discussionsReplies: 15Last Post: 25th Jan 2008, 22:09
