Hi,please help!
I have subtitles that i convert from dvd used VSrip but that dvd was PAL system & i want to put that subtitle in to MKV & after i put that subtitles in to my MKV but not sync.
my question is how to sync that subtitle?
many thanks.
If VobSubs (IDX/SUB), you can convert the framerate from 25fps to 23.976fps using such programs as SubtitleCreator.
Yes,it's IDX/SUB. I have tried with several ways but no luck at all,like:
-sub resync in VobSub packcage.
-BDSup2Sub.
I wil try use SubtitleCreator later.
thanks. -
Well, if i open sub/idx SubtitleCreator always say:
Error reading subtitle number 1 (Index was outside the bounds of the array.)
any idea what's wrong with that subt?
thanks. -
I don't know what's wrong. How did you create the VobSubs? VSRip? Maybe try a different program, one such as VobSub Configure (included in the VobSub package)
Sometimes opening them in Sub Resynch and just saving them again will fix them.
Me, I usually extract SUP format subs when demuxing using PGCDemux. I convert to VobSubs and also change the framerate in SubtitleCreator at the same time. -
VSRip is very easy tool for me,it's great,simple & fast & also can convert Close Captioned.
if i convert subtitles from dvd NTSC to put into MKV 23,976 i got no problem,audio & subtitle are very suitable. but,if from PAL to NTSC i got the big problem
Allright,i will try what you have said above. -
I know that this is a really old thread, but perhaps someone else came across this error, so here goes:
The error you describe is most likely connected to the file's character coding format.
If the .srt/.txt or any other text subtitle has been saved in UTF-8 instead of ANSI, SubtitleCreator throws this error.
To change that, open the text subtitle in an editor of your choice (Windows "Editor" will do, or Notepad++...).
- In Windows Editor you click "Save as"
- when the pop up asks you, where to save, look out for the little drop-down beneath "file type" (am using the German version, so don't know its exact English name) and there
- choose "ANSI", then save with a new name if you will,
because certain symbols and special characters will not be displayed correctly after that, musical notes, for example.
So you might want to check first, if the display still suits your needs. Now it should open without problems in SubtitleCreator.
Or you may use something like AVIAddXSub, which deals with UTF-8 correctly.
But you won't be able to change the timing in there.
So you may try this:
- First change the timing of the text format subs with SubtitleEdit,
- then use AVIAddXSub...
Hope this is of help to someone.
Need to convert 23,976 1080p to 25p PAL DVD
By JMantis in forum Video ConversionReplies: 8Last Post: 12th Apr 2012, 17:22 -
How to change fps in an MKV 25 down to 23.976 ?
By mahogany in forum Authoring (Blu-ray)Replies: 4Last Post: 13th Jan 2010, 21:19 -
Subtitles out of sync in mkv file
By Information in forum SubtitleReplies: 0Last Post: 8th Sep 2009, 14:13 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
