I know the title sounds crazy, but here's what I need. I have a dvd disc that requires you to use the remote control or hard buttons to play each track. My in-car dvd players for the kids, the remotes no longer work and the only hard buttons are play and skip. There is no way to make selections.
So, can I rip the disc and remove this requirement to where the disc will just start playing when inserted and will just play through all the tracks?
Rip the original to an ISO, Run the ISO through DVD Shrink, reauthor mode, drag all the titles you want from the right side to the left side, save to an ISO then burn with ImgBurn.
No menu's, the disc will start playing when inserted and continue through everything you included then stop when it is done. -
If it is a newer or commercial (pressed) dvd you will want to use something more current to rip it to your HDD to remove any copy protection.
Otherwise ImgBurn might choke on the ripping, and if not, odds are that shrink will choke trying to open the ISO/Image.
Or neither might not choke but then when you play it back it could be totally whacked.
I use DVDFab, you can use it for free for just ripping the entire disc, then open in Dvd Shrink, if you want to pay for it you can actually use DVDFab to rip the disc, bypass the copy protection and do the same thing that Dvd Shrink does.
Rip just the main movie and any extras you want with no menu's and have the disc just start and play through what you selected.
conversion blu-ray to dvd that select audio/subtitle tracks as requirement
By wisitch in forum Video ConversionReplies: 1Last Post: 5th Dec 2011, 06:13 -
By wisitch in forum Video ConversionReplies: 4Last Post: 25th Nov 2011, 08:04 -
Any min read speed requirement for flash drive?
By larrym in forum Newbie / General discussionsReplies: 2Last Post: 27th Nov 2008, 11:13 -
Rip DVD menu audio
By Silver_Ice in forum AudioReplies: 7Last Post: 28th Mar 2008, 00:33 -
After rip DVD menu not working, any suggestion?
By taylor6698 in forum DVD RippingReplies: 1Last Post: 3rd Oct 2007, 16:10
