  1. Hello,
    I want to backup some mkv action movies to xvid AVI in 2-pass (discard) mode with some filters in virtualdubmod.
    My question is should I create the pass file with all of the filters (that really slows the 1st pass down) or can I just do the 1st-pass without any filters to speed it up then add filters only to 2nd pass?
  2. Member leghorn's Avatar
    Apr 2007
    Germany
    Filters should definitely be applied in both passes. Since action movies come with loads of motion, a faster no-filter 1st pass will significantly drain quality of your output.
    Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski)
  3. All right. thanks!
