I need help!!!I have a DVD with a movie in 2 MP4 files. I converted the files to AVCHD using multiAVCHD program. I ended up with 2 files: HDV 0067 & HDV 0068 (each of this folders have 3 additional folders (ADV_OBJ, HVDVD_TS, and VIDEO_TS). How do I burn these 2 files to a DVD??? I have tried using ImgBurn without success. Any help would be greatly appreciated as these are movies of my wedding.
Additonal note. multiAVCHD also creaded a BDMV folder which appears to be empty!!?!
If you are creating a DVD then simply select the Video_TS folder in Imgburn. The rest aren't part of the DVD structure, but just something MultiAVCHD has created along the way.
Read my blog here.
Thank you for your reply. I had already tried that. I copied the VIDEO_TS folder using ImgBurn "Write files/folder to disc and it didn't work. The VIDEO_TS folder contains the following files: VIDEO_TS.BUP, VIDEO_TS.IFO, VTS_01_0.BUP, VTS_01_0.IFO, and VTS_01_1.VOB. Is my movie in any of these files?? There is also a folder named HVDVD_TS and another named ADV_OBJ besides the VIDEO_TS folder. Should I have copied the files inside the VIDEO_TS folder and not the folder itself???
If you select the folder video_ts in Imgburn, it will know you have a DVD and configure itself accordingly. If MultiAVCHD did it's thing, then that is your DVD. None of the other folders having anything to do with the DVD format, so including them is a waste of time.
Read my blog here.
Multiple AVIs to a single SD-DVD with MultiAVCHD
By jeffdb27 in forum Authoring (DVD)Replies: 3Last Post: 1st Jun 2012, 15:17 -
Dvd to Blu-ray multiAVCHD
By Marco33 in forum Authoring (Blu-ray)Replies: 5Last Post: 26th Jan 2012, 11:34 -
Problem with creating AVCHD file for ps3 using MultiAVCHD. Please help...
By Mike789 in forum Authoring (Blu-ray)Replies: 0Last Post: 22nd Dec 2011, 15:28 -
multiAVCHD and HD-DVD
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 19th Mar 2010, 09:05 -
m2ts files on DVD with MultiAvchd
By besthost in forum Authoring (Blu-ray)Replies: 2Last Post: 3rd Jul 2009, 04:06
