Results 1 to 9 of 9
  1. Anyone have a guide for this program! The help file isn't going that deep that I want!
    Regards
    Chris
    www.dvdcrazy.net
  2. Hi... I never seen videopack 5 guides yet...
    I have learned by myself with using the emulator and by making vcd images of my "essays" ...
    I learned how to use the "navigation connections" between menus and videos.. and also how to add background music and slideshow menus...
    Maybe you're looking for doing something special... If so, just tell me what you expect and maybe I will be able to help with screenshots or whatever
    Cya!
    Lady Tatjahna ;)
  3. Thanx!
    Yes i'm a little confused how to link buttons to chapters for a DVD project!
    Screenshots would be super since it seems to be a little tricky to do!
    And another thing! I have Windows XP and when I hit the record to DVD-r button the hole computer goes black and reboots!
    Regards
    Chris
    www.dvdcrazy.net
    Nov 2000
    GLoucester
    Try on my site just posted one.
    www.coyote01.freeserve.co.uk
    TOMMO
  5. good site Tommo,,,so,can you make a vcd with videopack5?
    thanks.
    Rigo.F
  6. Thanx a million Tommo!
    I'm doin DVDs but I gues it's the same!
    Regards
    Chris
    www.dvdcrazy.net
    Nov 2000
    GLoucester
    Yes you can use it for DVDs, principle is the same. If you play around with the buttons BORDER you can create very nice effects and even have them show up as clips of each of your chapters. Got to play around with the timing thing there.
    Yes VCDs and SVCDs can be done in the same way.
    TOMMO
    Jul 2001
    Pensacola, FL
    just wanted to let you know, that i just finished browsing your site and it's awsome. exrtremely helpful and explains things in depth but simply. keep up the good work, and will defenitely be going back often. peace
    Nov 2000
    GLoucester
    J Crew - thanks for the compiment - glad it was useful
    TOMMO
